Displays the number of members in the specified IGMP group subnet. If you do not specify a VRF name or range of VRF IDs, the results show information for the Global Router. If you do specify a VRF name or range of VRF IDs, the results show information only for the VRFs you specify.
show ip igmp group count member-subnet {A.B.C.D/X} group {A.B.C.D} detail [port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] [vlan <1-4059>] [vrf WORD<1-16>] [vrfids WORD<0-512>]
Identifies the slot and port in one of the following formats:
a single slot and port (slot/port)
a range of slots and ports (slot/port-slot/port)
a series of slots and ports (slot/port,slot/port,slot/port)
all ports on the same slot (slot/all)
all ports on the switch (all)
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
None
Privileged EXEC
